#1 2006-05-19 21:52
joacim
Insert blank space between lowercase and uppercase
Hi
Is it possible to insert a "blank space" between a lowercase and a uppercase i.e
HiMyNameIsJoacim -> Hi My Name Is Joacim
thnx
joacim
#2 2006-05-20 04:46
Re: Insert blank space between lowercase and uppercase
Hi joacim smile
Yes, it is possible, by using PascalScript rule, and here is the code:
function IsUpperCase(C: Char): Boolean;
  Result := C = UpperCase(C);
function IsLowerCase(C: Char): Boolean;
  Result := C = LowerCase(C);
function IsLetter(C: Char): Boolean;
  Result := UpperCase(C) <> LowerCase(C);
  I, Len: Integer;
  Len := Length(FileName);
  for I:=Len downto 2 do
    if IsLetter(FileName[i]) then
    if IsUpperCase(FileName[i]) and
       IsLowerCase(FileName[I-1])
    then Insert(' ', FileName, I);
#3 2006-05-20 09:42
joacim
woow! it works just perfect.
You saved my day! yikes
Thnx!
:yes:
#4 2008-02-16 15:42
Just to update:
Because ReNamer went into full Unicode support since v4.00, the code posted above raises "Type Mismatch" error when used on latest versions. This is because the type of the FileName variable changed to WideString, which makes the type of each character FileName[i] type WideChar, instead of the expected Char type by the used functions in the script.
For current version of ReNamer v5.20, the code below will do the same job:
  Separator = ' ';
  I: Integer;
  for I:=WideLength(FileName) downto 2 do
    if IsWideCharAlpha(FileName[i]) then
      if IsWideCharUpper(FileName[i]) and
         IsWideCharLower(FileName[I-1])
      then WideInsert(Separator, FileName, I);
#5 2008-09-09 22:52
Tom221
I tried this and it works to a point. If you have the words I or A it does not separate them.
For Example: TheEverlyBrothers - AllIHaveToDoIsDream.mp3 becomes The Everly Brothers - All IHave To Do Is Dream.mp3
Is there a way to fix this?
Thank you
#6 2008-09-10 08:10
Thank you
Not easy since ABBA would become A B B A then ;-)
We would need an array of exceptions for that issue (i think)
I have tried to modify the script from Denis to solve your current problem,
but as i said, this is no general solution :
// http://www.den4b.com/forum/viewtopic.php?id=14
// Is it possible to insert a "blank space" between a lowercase and a uppercase i.e
// HiMyNameIsJoacim -> Hi My Name Is Joacim
//update 21.Feb.2008 for ReNamer > 4
//update 09.Sep..2008 for Tom221 issue with "IHave"
  Separator = ' ';
  I: Integer;
else
          IsWideCharUpper(FileName[i-1])
I have simply added
else
          IsWideCharUpper(FileName[i-1]);
I have also tried with
IsWideCharBlank(FileName[i-2])
but no success due i have no time yet and i am not good in coding.
#7 2008-09-10 15:07
Tom221
Thanks Joacim
That worked like a charm
Have a good day
#8 2008-09-14 13:32
The previous code by Stefan can be simplified into this:
  SPACE = ' ';
  I: Integer;
      if IsWideCharUpper(FileName[i]) then
        WideInsert(SPACE, FileName, I);
This will put a space in front of ALL CAPITAL letters.
#9 2008-09-14 14:36
Tom221
Thanks for your reply. Your code would be great if that was what I wanted to do.
I wanted to separate words in a audio file name and the above code did this but left behind a problem with, for example, "IHave" would not separate. The extra code by Joacim did this fine.
I will keep your code in mind if that situation comes up.
Thanks again
#10 2015-10-02 04:55
lanceru
Thanks for the Pascal code den4b.
I had a bit more similar but complex question from a different thread that utilized RegExp. It seems Pascal may be the way to go.
lanceru wrote:
What if I only want to add a hyphen, before only the 2nd capitalized word?
Or,
At only the 3rd capitalized word?
Or,
For the 2nd and 3rd capitalized words (specify range)?
I have a file named:
JimCanson_DepartmentManufacture,
and then transform it to:
Jim_Canson_DepartmentManfacture, not Jim_Canson_Department_Manufacture
In any case I'm mainly just interested in the first question.
"What if I only want to add a hyphen, before only the 2nd capitalized word?"
The closes I can come up with
  Separator = '_';
  I: Integer;
  for I:=2 to 100 do
      if IsWideCharUpper(FileName[i]) and IsWideCharLower(FileName[I+1])
      // break; this results in an error message.
I need a way to terminate the loop.
