ReNamer:Scripts:RegEx Case Convertion
(Redirected from ReNamer:Scripts:Case conversion based on RegEx)
Jump to navigation
Jump to search
The script compensates for the lack of the ability of ReNamer's RegEx engine to change case of groups captured by RegEx.
User needs to provide REGEX and CHANGE_CASE parameters to the script controls. The exact form of the CHANGE_CASE string is explained in the legend below the main controls.
Tested
- ReNamer 5.74.4 Beta
Code
Author: krtek. Date: 26 July 2009.
//SCRIPT CONTROLS:
REGEX = '(.+) - (.+) - (.+)';
CHANGE_CASE = '102';
SKIP_EXTENTION = true; //true or false
CASE_SENSITIVE = False; //Should searching with regex be case sensitive? Default: False
FULL_MATCH_CHECK = True; //Should the script warn you if regex didn't match the full filename? Default: True;
//Legend for CHANGE_CASE parameter:
//1. Capitalize Every Word
//2. lowercase
//3. UPPERCASE
//4. iNVERT cASE
//5. First letter capital
//0. No changes
//You may specify case for every capturing group (brackets) in regex as a string of appropriate digits.
//If the CHANGE_CASE string is shorten then number of capturing groups then the last digit is used till the end of regex.
//If the CHANGE_CASE string is longer, spare digits are ignored.
//eg. '102' means that first matched brackets will be uppercased,
// second - won't be changed and third (and every brackets after it) - lowercased.
//END OF SCRIPT CONTROLS
BREAK_STRING = 'BREAK';
FOR_ALL_STRING = 'DO NOT ASK';
STANDARD_ANSWER = BREAK_STRING+' to exit, '+FOR_ALL_STRING+' to continue';
Matches, SubPatterns : TWideStringArray;
TempFilename, FileNameProcessedPart : WideString;
start_pos, end_pos, i, j : Integer;
Initialized, TimeToExit, NotAFullMatch, CheckIfFullMatch : Boolean;
CaseFlags : array of Integer;
CaseFlag : Integer;
Answer : WideString;
function SetCaseFlags(s : WideString) : array of Integer;
i : Integer;
LoopEnd : Integer;
CaseIDs : array of Integer;
SetLength(CaseIDs,Length(s));
LoopEnd:=Length(s)-1;
for i:=0 to LoopEnd do
CaseIDs[i]:= StrToInt(WideCopy(s,1,1));
s:=WideCopy(s,2,Length(s)-1);
result:= CaseIDs;
procedure Initialize;
Answer:=STANDARD_ANSWER;
CheckIfFullMatch:=FULL_MATCH_CHECK;
Initialized:=true;
CaseFlags:=SetCaseFlags(CHANGE_CASE);
if not TimeToExit then
if not Initialized then Initialize;
TempFilename:='';
end_pos:=0;
start_pos:=1;
SetLength(SubPatterns,0);
SetLength(Matches,0);
NotAFullMatch:=false;
if SKIP_EXTENTION then
FileNameProcessedPart:=WideStripExtension(FileName)
else
FileNameProcessedPart:=FileName;
Matches:=MatchesRegEx(FileNameProcessedPart, REGEX, CASE_SENSITIVE);
if Length(Matches) <= 0 then exit;
if Matches[0] <> FileNameProcessedPart then NotAFullMatch:=true;
SubPatterns:=SubMatchesRegEx(Matches[0],REGEX,CASE_SENSITIVE);
if Length(SubPatterns) <=0 then exit;
for i:=0 to Length(SubPatterns)-1 do
if SubPatterns[i]<>'' then
end_pos:=WidePos(SubPatterns[i], Matches[0])-1;
TempFileName:=TempFileName+WideCopy(Matches[0], start_pos, end_pos-start_pos+1);
start_pos:=end_pos+Length(SubPatterns[i])+1;
if i < length(CaseFlags) then
CaseFlag:=CaseFlags[i]
else
CaseFlag:=CaseFlags[Length(CaseFlags)-1];
case CaseFlag of
0 : TempFilename:=TempFileName+SubPatterns[i];
1 : TempFilename:=TempFileName+WideCaseCapitalize(SubPatterns[i]);
2 : TempFilename:=TempFileName+WideLowerCase(SubPatterns[i]);
3 : TempFilename:=TempFileName+WideUpperCase(SubPatterns[i]);
4 : TempFilename:=TempFileName+WideCaseInvert(SubPatterns[i]);
5 : TempFilename:=TempFileName+WideUpperCase(SubPatterns[i][1])+
WideLowerCase(WideCopy(SubPatterns[i], 2, Length(SubPatterns[i])-1));
else
WideShowMessage('The value of CHANGE_CASE constant is invalid. Check legend for info.');
TimeToExit:=True;
break;
if start_pos < Length(FileNameProcessedPart) then
TempFilename:=TempFileName+WideCopy(FileNameProcessedPart, start_pos, Length(FileNameProcessedPart)-start_pos+1);
if NotAFullMatch then
if CheckIfFullMatch then
if not WideInputQuery('RegEx didn''t match the full filename.', 'Old filename:'+#10+FileName+#10+#10+
'Proposed new filename: '+#10+TempFileName+WideExtractFileExt(FileName)+#10+#10+
'What should we do?'#10+#10+'Pressing OK button = Rename that file'+#10+
'Pressing Cancek button = Skip that file'+#10+'Type '''+BREAK_STRING+
''' in the text field to exit the script or '''+FOR_ALL_STRING+
''' if you want to continue with all the files.'+#10, Answer) then Exit
else if WideSameText(WideLowerCase(Answer),BREAK_STRING) then
TimeToExit:=True;
exit;
end
else if WideSameText(WideLowerCase(Answer),FOR_ALL_STRING) then
CheckIfFullMatch:=False;
end
else
FileName:=TempFileName+WideExtractFileExt(FileName)
else FileName:=TempFileName;
end
else exit;
Code 2
Thanks to the Stefan's involvement there exists also a version of the script that uses dialog boxes to ask user for required data so no direct changes to the script are needed.
Author: krtek & Stefan. Date: 27 July 2009.
//SCRIPT CONTROLS:
DEFAULT_REGEX = '(.+) - (.+) - (.+)'; //exchanged with InputQuery
DEFAULT_CHANGE_CASE = '102';
//0. No changes
//2. lowercase
//3. UPPERCASE
//4. iNVERT cASE
//second - won't be changed and third (and every brackets after it) - lowercased.
SCRIPT_NAME = 'krtek''s CaseChanger';
start_pos, end_pos, i: Integer;
CaseFlag : Integer;
Answer, Regex, ChangeCase, Info : WideString;
function BoolToStr(condition : boolean) : WideString;
If condition Then
result := 'True'
Else
result := 'False';
procedure procGetUserInput;
Info := Info + #10 + 'Note: check script source for this settings:' +#10
Info := Info + 'SKIP_EXTENTION: ' + #9 + BoolToStr(SKIP_EXTENTION) +#10
Info := Info + 'CASE_SENSITIVE: ' + #9 + BoolToStr(CASE_SENSITIVE) +#10
Info := Info + 'FULL_MATCH_CHECK: ' + #9 + BoolToStr(FULL_MATCH_CHECK) +#10
Regex:=DEFAULT_REGEX;
If not WideInputQuery(SCRIPT_NAME, 'Match this RegEx on file name:' +#10 +Info, Regex) then
TimeToExit := true;
exit;
Info := '0. No changes' +#10
Info := Info + '1. Capitalize Every Word' +#10
Info := Info + '2. lowercase' +#10
Info := Info + '3. UPPERCASE' +#10
Info := Info + '4. iNVERT cASE' +#10
Info := Info + '5. First letter capital' +#10 +#10
Info := Info + 'F.ex.:' +#9 + 'use case type 1 for first match ( ),' +#10 +#9
Info := Info + '0 for second and 3 for third' +#10 +#9 + '=> 103' +#10 +#10
ChangeCase := DEFAULT_CHANGE_CASE;
If not WideInputQuery(SCRIPT_NAME, 'Choose case for every single match group ( )'+#10+
'of your RegEx:' +#10 + Regex +#10 +#10 + Info, ChangeCase ) then
TimeToExit := true;
exit;
i : Integer;
LoopEnd : Integer;
result:= CaseIDs;
FilePath := 'not used'; //just to shut up the compiler
procGetUserInput;
CaseFlags:=SetCaseFlags(ChangeCase);
Initialized:=true;
TempFilename:='';
end_pos:=0;
start_pos:=1;
else
Matches:=MatchesRegEx(FileNameProcessedPart, Regex, CASE_SENSITIVE);
SubPatterns:=SubMatchesRegEx(Matches[0],Regex,CASE_SENSITIVE);
else
CaseFlag:=CaseFlags[Length(CaseFlags) -1];
case CaseFlag of
else
WideShowMessage('The value of ChangeCase parameter is invalid.' +#10+
'ChangeCase string cannot contain '+inttostr(CaseFlag)+ '.'+#10+
'Check legend for info.' +#10 +#10 +'Script will be terminated.');
TimeToExit:=True;
break;
'Old filename:'+#10+FileName+#10+#10+'Proposed new filename: '+#10+
TempFileName+WideExtractFileExt(FileName)+#10+#10+'What should we do?'#10+#10+
'Pressing OK button = Rename that file'+#10+'Pressing Cancek button = Skip that file'+#10+
'Type '''+BREAK_STRING+''' in the text field to exit the script or '''+FOR_ALL_STRING+
TimeToExit:=True;
exit;
end
end
else
end
else exit;
