Well, I'm trying something on ReNamer and I was thinking if I could take the hashes from Hasher (through command line) instead of ReNamer's meta-tags.
I'm trying just for more speed... Is it possible?
Hasher doesn't work in command line mode yet, but you should be able to find several tools out there that do.
OK, no problem, thanks.
