What's New:
* Integrated Windows XP Manifest to allow visual styling;
* Modified ID3v2 libraries to support reading of the unicode data (experimental);
* Added reading support for ID3_PartOfSet tag in ID3v2 libraries (experimental);
* Added "open containing folder" option to the context menu of the files table;
* Main menu and toolbar shortcuts are no longer available when editing new name;
* No more error when using empty Replace or Remove rules in wildcards mode;
* Added/changed a number of shortcuts in the options and files context menu;
* State column is sorted by file status and then by marked/unmarked state;
* New Project action will clear files and then rules, escaping auto-preview.
* Rule descriptions are added to the localizable resource strings;
* Right-to-left character-wise processing of delimiters if reversed;
* Status bar panels are resized automatically with the form;
* Changed ambiguous Ctrl+Z,X,C,V files manipulation shortcuts;
* Fixed offset when using Insert rule with right-to-left position;
* Added option to disable confirmation dialog for overwriting files;
* Auto apply rules option in Analyze dialog works on context menu too;
* Corrected handling of double clicks and right clicks on rules checkboxes;
* Fixed mark/unmark all rules option not triggering auto preview;
* Fixed disappearing modified star after cancelling save preset dialog;
* Fixed contradiction between Importing feature and Auto Preview option;
* Fixed some cropped texts when custom system fonts are used;
* Both ' and ` are handled when capitalizing words;
* Added line wrap option to the Analyze dialog;
* Added French translit alphabet;
* Small user interface improvements;
