This is a major update. It includes many new features which were developed in the period of last 2-3 months. There is a bit for everyone: new IPTC tags and EXIF library for image processing, integration of filters with presets for easy handling, new functions and filename encryption script for PascalScript rule, dialog for creating links to all presets, and more.
On the other hand, work on the new versions of Shutter and Hasher has slowed down, but I hope it is just temporarily.
What's New:
* Added ability to save Filter Settings together with a Preset;
* Added split panel in status bar to display current preset and modification sign;
* Added dialog for creating links to all presets, with load and rename options;
* Integrated dEXIF libraries to parse EXIF tags (works on problematic JPEG files);
* All EXIF* tags should work on TIFF files too, alternatively to TIFF* tags;
* Added 5 IPTC tags: ObjectName, Caption, Headline, Location, City;
* Fixed problem with setting the files date on Windows 9x platforms (v5.10 bug);
* Fixed access violation when importing file paths and new names (v5.xx bug);
* Fixed bug which stopped the largest binary signature from being detected;
* Updated binary signature detection to support Unicode filenames;
* Added IntToHex, HexToInt and HexToIntDef functions to PascalScript;
* Added Base64Encode and Base64Decode functions to PascalScript;
* Added a script to encrypt filenames using XOR-BASE64 algorithm;
* Option to highlight changed names is now case sensitive;
* Added "fix conflicting new names" option to the Options menu;
* Added shortcuts to buttons in PascalScript rule;
* Added "none of the above" option to Case rule;
* Fixed few spelling mistakes;
