#1 2008-01-30 01:00
ReNamer 5.20 and Shutter v3 progress
That's a first one this year, and for last few months too wink Crazy time, work, documents, project deadlines, presentations, certifications, etc. Nevertheless, I still try to find time to work on my tools, and here is one part of the effort over these months. Many changes has been made since the last release, so you might want to have a quick look through the changelog because I am sure that you'll find something useful for your-self smile
On the other hand, considerable time was spent for re-designing and re-working Shutter. Bits and pieces are coming together now, and hopefully I'll have a release candidate soon ready for testing. If anyone wants to have a pre-release look at it - you can contact me for more details. The underneath structure has pretty much stabilised now, but looks and feels of things do require some user attention.
What's New in ReNamer:
* Added /list command line parameter to load list of files from text file;
* Fixed accessibility problem when adding files while browsing modal forms;
* "Import files" option handles Unicode and UTF8 content (with BOM);
* Added "detect using binary signature" option to the Extension rule;
* Added option to Export/Import list of new names to/from clipboard;
* Export/Import functions have their own button and menu;
* Added "clear renamed files on rename" option in the settings;
* All HTML based help files are united into a single PDF;
* Added new section in the help file which describes renaming rules;
* PascalScript component has been updated to the latest v3.0.27.651;
* Added drag and drop support for scripts in PascalScript code editor;
* Added "go to" functionality for quick line jump in PascalScript;
* Added "apply rules for each line" option to the Analyze dialog;
* "Auto apply rules" action in Analyze dialog trigged on change of rules;
* "Analyze name" option will work on all selected files, not just focused;
* Added File_FileName, File_BaseName and File_Extension meta tags;
* Folders in "Add Folders" dialog are explicitly sorted;
* Option to resort files has become a long-term option;
* Added choice of Replace or Insert for the UserInput rule;
* Added InputBox and InputQuery functions to PascalScript;
* Added WideGetEnvironmentVar function to PascalScript;
* Added FileAppendContent function to PascalScript;
* Analyze dialog will apply only marked rules;
* Updated Russian translit alphabets;
* Analyze dialog became non-modal;
