Summary of the changes in this release: command line renaming, natural sort, filter masks, flac/wma tags, updated components and other smaller usability fixes/improvements. Also, don't forget to check out updated "Beginner's Guide" and "Quick Start", written by Lance Smith.
What's New:
* Added "Masks" option to the Filter Settings;
* Updated VirtualTreeview and TntUnicodeControls components;
* Added Command Line Renaming parameter, to rename without user interaction;
* Added Mark and Unmark All options to context menu of the rules table;
* Installer updated: default scripts, translits and help files will always be overwritten;
* Height of the rules table is remembered for "remember last position and size" option;
* Fixed problem when "Filter Settings" dialog opened within "Add Folders" dialog;
* Added experimental option "use natural order sorting algorithm" (2-3 times slower);
* Fixed problem with usage of ":" and "\" symbols in some of the rules;
* TIFF tags are no longer represented by EXIF tags, as it may be misleading;
* More meta tags will now work with Unicode filenames and contents;
* Last used folder in the "Add Folders" dialog is remembered;
* Added WideCaseCapitalize() and WideCaseInvert() to PascalScript;
* The checked state of the rules is saved in the presets;
* Fixed problem with relative paths passed via the command line;
* Added WMA and FLAC artist/title/album/year/genre/track meta tags;
* Audio_Duration* tags work for FLAC files;
* Improved new filepath validation;
