#1 2007-02-01 01:00
ReNamer 4.50
This is a big update. Large amount of effort went into these changes and additions, which were accumulating since the previous release. Many improvements were made to PascalScript rule, from usability and functionality points of view. Finally, RemObjects, the producers of PascalScript component, were kind enough to fix the problems which I have reported about 6 months ago! Users of PascalScript, please, have a look at the list of changes - some crucial functions have been changed. From another perspective, there is a great addition to the meta tags - tags for retrieving duration of audio files. Wanted to add that a long time ago, but didn't have the right libraries until recently. Plus, other small changes/additions.
What's New:
* Added meta tags to retrieve duration of Audio files: MP3, WMA, OGG, WAV!
* Updated PascalScript source to the latest January SVN release,
  which has finally addressed previously reported by me issues, now:
  1) SetLength() and Length() functions work for both WideStrings and Arrays;
  2) Widestring indexed character access is working, i.e. WideString[1];
  Note: WideArrayLength() and WideArraySetLength() functions are removed!
* Added 8 new functions to PascalScript rule: SetFileTimeCreated,
  SetFileTimeModified, SetClipboardText, GetClipboardText, ReplaceRegEx,
  MatchesRegEx, CalculateMetaTag, FileReadFragment;
* Wildcards can now be used within Remove and Replace rules!
* Files selection mask is remembered for the entire session;
* JPE file extension is treated as JPEG format, for meta tags;
* Help files will now be opened with the default web browser;
* Added Help item, which will encapsulate all related help documents;
* Added new "Move filename portion" script for PascalScript rule;
* Capture run-time exceptions when executing PascalScript rule;
* Fixed problem with extension in "Serialize duplicates" script;
* Fixed few typos within function reference in PascalScript help file;
* Tabulation and selection helpers for script editor in PascalScript rule;
* Added Hours Span script, which adds/subtracts hours from dates in filenames;
* Count of selected and marked files will now be displayed in the status bar;
* Fixed tool bars in the main window and in the presets manager to support manifest;
* Fixed ignoring of the option "Auto preview on change of rules configuration"
  when states of the checkboxes of the rules are changed;
* Last used values for dialogs "Mark by mask", "Select by filename length",
  "Select by extension" and "Select by mask" - will now be remembered;
* Multiple masks/extensions can be defined in dialogs "Mark by mask",
  "Select by extension" and "Select by mask".
* Added "Apply rules to the clipboard" option;
* Added Turkish translit alphabet;
