#1 2006-11-08 01:00
ReNamer 4.20
Time to release the latest beta as a stable version, because no problems were found with the latest modifications and additions. I already have planes for the next release, and a big part to that plan is the addition of the drop-box/hot-spot to make addition of files into ReNamer as convenient as possible. Another good news is that Spanish and hopefully Ukrainian localized versions of ReNamer should be available soon, thanks to few users dedicated into translations!
What's New:
* Added "Add to ReNamer" option for files, yet it is not recommended to be used;
* Added "Auto preview when new files are added" option to the settings;
* Added "Close program after successful rename" option to the settings;
* Auto preview options now turned on by default, for new installations;
* Fixed process of pasting text from clipboard into the new name editor;
* Removed warning when auto-sizing columns with more than 15'000 files;
* Removed confirmation message when pasting files into ReNamer;
* Changed options that configure default behavior for adding folders;
* Pressing the return key within a spin number editor in rules will submit the form;
* "First letter capital" option will capitalize the first letter, not the first character;
* Date and Time meta tags have been united, for performance reasons;
* Added procedure Sleep(Milliseconds: Cardinal) for PascalScript;
* Added Date_Now meta tag, which represents current date;
* Added Name Length and New Name Length columns to the files table;
