This update is mostly Windows 9x related fixes...
What's New:
* Added option to Hide Tray Icon, which can make Shutter invisible;
* Fixed rare flickering effect and closing problem of Tray's popup menu;
* Fixed problem with execution of Shutdown action on Windows 9x platforms,
caused by badly documented EWX_FORCEIFHUNG switch in Windows API;
* Fixed long paths showing instead of filenames in the dropdown menu
for the Process Stops event, occurred only on Windows 9x platforms;
* Fixed problem with writing INI file on Windows 98 platform, which raised
a page fault error when user tried to close an application.
* Some graphical changes to the Options form;
