Program emerged as a result of a BackUp Utility project break-up.
Basic idea of this part of the project was to calculate a hash for a file using different algorithms.
Idea was expanded, new features were introduced:
* calculating a hash for a string,
* calculating hash for a list of files using multi-threaded techniques,
* search for duplicated files using their hashes as matching criteria.
Some of the supported Hashes and Checksums: MD5, CRC32, SHA1.
Couple of screenshots available from the Projects page.
Project is in its Alpha stage at the moment, bits and pieces coming together, soon enough its Beta version will be available for public download
