#1 2005-04-12 01:00
No life, just ReNamer... ;)
Some say: "It's the best renaming tool I've ever used",
some say: "Powerful and easy to use, unlike the other renamers",
some say: ...
I will say Thanks!
It took me some time and some effort to get to this stage, and I'm not stopping here!!!
ReNamer 1.73
* Support for parameters, supplied files and folders will be added to the table;
* Option to register a preset *.rnp extension;
* Option to add ReNamer to the context menu of the folders;
* added About tab to About Form, with shell executable email and web addresses;
* added menu item to Browse the Presets folder;
* small graphical improvements to the buttons control panel;
* added shortcuts Ctrl+1,2,3,4,5,6,7,8,9 to first 9 presets;
* fixed: Presets Manager would rename a preset to ".rnp" when new name is an empty string;
* fixed: space on its own and spaces on both sides of text parameters were not saved in Presets;
* corrected some typos;
* small changes and improvements;
Plus to all that, now ReNamer comes with an Installer/Uninstaller, enjoy:)
