#1 2018-04-02 14:06
MOT
Rename according to a comma-separated mapping file
I have a problem that is similar but not identical to Reading text from a file.
I have a text file which, on each line, contains the current name of a file and a text string that I would like to prepend to the filename. Example:
RB130123, CRB100999
LP120765, CLP120252
Resulting filenames should be:  CRB100999-RB130123, and CLP120252-LP120765
How would I accomplish this? I presume by using a PascalScript. Can anyone help me figure this out?
Thank you.
Edit: Originally posted in Reading text from a file, moved by moderator.
#2 2018-04-05 03:15
Re: Rename according to a comma-separated mapping file
The script below will accomplish what you need.
At each preview, it will ask for a full path to the file containing the comma-separated file name mappings (map file). It will the load the map file, and will find and insert an appropriate mapping into each filename. You could also hardcode the map file path inside the script, so that it wont be asked on every preview.
  MapFilePath: WideString;
  Initialized: Boolean;
  TargetName: String;
  SourceNames, TargetNames: TAnsiStringArray;
procedure LoadMapFile(const FileName: WideString);
  Lines: TAnsiStringArray;
  Line: String;
  I, DelimPos: Integer;
  Lines := FileReadLines(FileName);
  SetLength(SourceNames, Length(Lines));
  SetLength(TargetNames, Length(Lines));
  for I := 0 to Length(Lines) - 1 do
    Line := Lines[I];
    DelimPos := Pos(',', Line);
    if DelimPos > 0 then
      SourceNames[I] := Trim(Copy(Line, 1, DelimPos - 1));
      TargetNames[I] := Trim(Copy(Line, DelimPos + 1, Length(Line)));
    end
    else
      SourceNames[I] := '';
      TargetNames[I] := '';
function FindMapping(const SourceName: String): String;
  I: Integer;
  Result := '';
  for I := 0 to Length(SourceNames) - 1 do
    if Length(SourceNames[I]) > 0 then
    if WideSameText(SourceName, SourceNames[I]) then
      Result := TargetNames[I];
      Exit;
  if not Initialized then
    Initialized := True;
    MapFilePath := WideInputBox('Map file path', 'Enter full path to the map file:', '');
    if Length(MapFilePath) > 0 then
      LoadMapFile(MapFilePath);
    TargetName := FindMapping(WideExtractBaseName(FileName));
    if Length(TargetName) > 0 then
      FileName := WideExtractBaseName(FileName) + '-' +
        TargetName + WideExtractFileExt(FileName);
P.S. It is usually better to start a new thread instead of reviving a 10 year old thread, and then link to other relevant threads if needed.
#3 2018-04-05 03:37
MOT
Thank you!
I suppose you're right about reviving an old thread.
I actually found a batch file example that does what I need, also. The following line, in a batch file, will read items from a text file (files.txt) with two columns separated by a tab, and rename the filename in the first column with the name in the second column:
for /F "tokens=1,2" %%a in (files.txt) do ren "%%a" "%%b"
