Can one make annotations to presets? E.g., add an annotation to this preset like to adapt the "Filters" and such?
There is no official way to add comments to rules or presets, yet.
There is an unofficial way using Pascal Script rule with the whole script consisting of a code comment, as described here: Add comments for rules.
Incidentally, which would be more useful?
A) a separate "Comment" rule,
B) a generic comment field per rule,
C) some other way?
Alright, thank you, so I will do it.
Incidentally, which of two would be more useful?
C) some other way?
I would say, in any case B): so one knows what, to which rule a comment refers to, (may be "Comment", clickable, opening the annotation, at the end of a rule in the upper pane)
And C), I would say, an annotation to set for the preset (generally). Both A) and C) could open in the same window, so one could see / edit all of the rules without opening them separately.
An annotation (may be dis/activatable by the user), respectively the existing of one, could be automactially displayed (when one opens a preset may be showing something like "Annotation!" or such, clickable opening a window) that there is a rule at all, so without having to look for a rule which might exist.
Or, if the effort is too big for the above just a commentation function per preset and the display that there is a comment after one has loaded the preset. So one could note something like: Comment to rule 2: etc.
At the moment this manner appears to be quite useful, so one cannot miss a comment:
May be like the above on the screenshot (may be easier to code), the same field (one creates with a rule in the "Edit rule" window but empty named "Comment" indented under the rule to be commented. And the same with a general comment for the preset on top of the rules (may be something like "Comment for preset" / "Preset annotation") or at the bottom. May be in the middle / colored or indented.
Thanks a lot for your feedback!
This will help shape up the commenting feature when the time comes to implement it.
You are very welcome!
Rule comments have been implemented in ReNamer 6.8.0.4 Beta.
- You can add/edit rule comments via the rules context menu, or using a Shift+Enter hotkey.
- Comments are displayed in the Statement column, replacing the auto-generated rule description, when available.
That's great, thank you very much!
