Version: Hasher 3.3
Current behavior:
Options -> Export file info to clipboard (Shift + Ctrl + C)
C:\file.zip
File size: 1.65 MB
Attributes: -----A-
Created: 0000-00-00 00:00:00
Modified: 0000-00-00 00:00:00
CRC32: ...
MD5: ...
SHA1: ...
SHA256: ...
Requested change:
Always show the number of bytes in the "File size" attribute when exporting the file info to the clipboard.
C:\file.zip
File size: 1.65 MB (1,726,212 bytes)
Attributes: -----A-
CRC32: ...
MD5: ...
SHA1: ...
SHA256: ...
More examples:
File size: 1 B (1 byte)
File size: 2 B (2 bytes)
File size: 1.35 GB (1,452,155,968 bytes)
Thank you for the suggestion and taking time to explain it in details.
This feature has been implemented and will be included in the next version of Hasher.
