#1 2014-05-11 20:36
Shutter 3.5
We have a small update for Shutter.
Most significant user experience change is that the option to "stop events when computer is going to hibernate/sleep and restart when wakes up" has been broken down into 3 separate options, to allow fine tuning Shutter's behavior depending on whether computer is going to hibernation/sleep or resuming from it.
Full list of changes in Shutter 3.5:
* Option to stop events when computer is going to hibernate/sleep and restart when wakes up has been broken down into 3 separate options;
* Hints for use of URL and MAILTO links in Open File action;
* Do not strip path from the file parameter in Open File action statement when URL or MAILTO links are used;
* Display "No additional configuration available" instead of blank panel;
* Updated icons in action configuration panels;
* Added copyright notices in Copyrights.txt;
* Updated icons in the Settings dialog;
* Added hint to run as administrator when failed to apply system settings;
* Removed donation link (donations are discontinued in favor of "Pro" version);
