#1 2006-05-06 23:06
ejay
Shutter creates *.tmp files?
I run Shutter as a command line from syncback (automatically shuts down my computer after backing up)... but find that I have huge *.tmp files created in my C:\Temp directory. I think this is caused by shutter and wonder if you have any suggestions?
Thanks for the Great program.
#2 2006-05-06 23:44
Re: Shutter creates *.tmp files?
Hi ejay,
No, those *.tmp files were not created by Shutter. The only file that Shutter creates is the Shutter.ini (in the same directory as Shutter.exe).
Denis.
