#1 2007-10-12 01:00
ReNamer 5.10
Yet another update ;-) This time for ReNamer. Several fixes, several additions, and the most importantly, full support for renaming of Windows network files! Also, Analyze dialog has been improved, with auto-apply option and Unicode capable text processing.
What's New:
* Windows network files renaming support;
* Added "new path" column to the files table;
* Added "auto apply rules" option to Analyze dialog;
* Added "right-to-left" option for position parameter in the Insert rule;
* Added "leave delimiter" option for delimiter parameters in the Delete rule;
* Selection is displayed for both In and Out text boxes in the Analyze dialog;
* SetFileTimeModified and SetFileTimeCreated will also work for folders;
* Fixed disappearing table menu after editing new name via "click through";
* Added two Russian translits, with alternative and extended Latin spellings;
* Added "clear not changed" option to the files table;
* Added "new project" menu item, with Ctrl+N shortcut;
* Analyze dialog in now Unicode capable;
* Some of the icons are updated;
