#1 2007-09-17 01:00
ReNamer 5.05
Small update which addresses several important issues with the previous version.
What's New:
* Added "Exif Date" column to the files table;
* Dialog for analyzing sample text is now resizable;
* Added html-based "Quick Start" guide to the Help files;
* Show "Quick Start" guide prompt on the first time run;
* Added "Prepare for SharePoint" option to CleanUp rule;
* Fixed potential incorrect date comparison for sorting procedure;
* Fixed "Clear files table on rename" option, did not work properly in some cases;
* Fixed rare false invalid by validation for Non-ASCII filenames (v5.00 bug);
* Fixed hidden rules table when "Remember last position and size" used (v5.00 bug);
