#1 2007-05-01 01:00
Shutter 2.85
This update contains several small but useful additions and modifications.
What's New:
* Added option for the shutdown message to stay on top of other windows;
* Added option to minimize all windows before showing shutdown message;
* Added option to disable "Cancel" button in the shutdown message;
* Increased maximum length of the number of seconds in Low CPU Usage event;
* Increased maximum length of the number of seconds in Ping Stops event;
* Font has been changed to "MS Shell Dlg" for NT platforms to support ClearType;
* Fixed problem with unsaved settings caused by some shutdown procedures;
* Added "Offline Only" option to the Battery Low event, which will allow
  triggering the event only when computer is running on battery;
