#1 2007-03-11 01:00
ReNamer 4.60
Another relatively big update, containing changes which were accumulating from the previous release. Most of these changes are for improvement of the user experience while using the program. Default behavior for adding folders is finally combined into a global configuration, so it defines behavior for the entire program, which might later be expanded with file masking parameters. Also, support of command line parameters and wildcards is enhanced.
What's New:
* Dramatically speeded up process of auto-sizing file table columns;
* Added options for showing hidden and system folders in "Add Folders" dialog;
* Generalized filter settings aka "default behavior for adding folders";
* Added option to include system files, in filter settings;
* Added new WideScanDirForFolders() function to PascalScript;
* ExecConsoleApp() function will convert OEM output to ANSI;
* Function WideScanDir() has been changed to WideScanDirForFiles();
* Substitution of wildcard matches in Replace rule using $1, $2, $3, etc;
* Fixed a small problem when matching entire filename with * wildcard;
* Removed already needless WideGetChar function from PascalScript;
* Support for masked paths in the command line, e.g.: "C:\Temp\*.jpg";
* Added option to mark only changed files (in terms of new names);
* Option which adds program to files context menu has been removed;
* Added option which adds program to "Send To" context menu;
* Fixed the rest of incompatibilities with the XP manifest;
* Added Serbian and Serbo-Croatian translit alphabets;
* Improved command line parameters handling;
* Collection of help documents was expanded;
