#1 2006-09-11 01:00
ReNamer 4.15
This update gives PascalScript even more power, with ability to execute external applications and even provide the captured output of the console mode application. Now, previously impossible tasks like extracting date from DV and CRW files - are possible, using 3-rd party tools for extraction and this new functionality for capturing their output and reusing in ReNamer! Also, another important addition is the "Real-time update of the preview" option, which will update files in the table one-by-one while generating new names, to provide some sort of feedback on the progress.
What's New:
* Added new PascalScript function WideFileSize to retrieve a size of a file;
* Help window is no longer modal (doesn't block other windows when opened);
* Skip extension made optional for the CleanUp rule, instead of default;
* Invalid meta tags or text with escape symbols will not be stripped out;
* Added new option to the Settings: Real-time update of the preview;
* Added new PascalScript functions ExecuteProgram and ExecConsoleApp
  which let user run an external program or a console mode application providing
  captured output and exit code;
