#1 2006-08-11 01:00
Latest ReNamer and Back to Russia :)
I'm finally getting my holidays that I've been waiting so much! And since I will not be developing while I'm away, I decided to release the latest development version of ReNamer - which has quite a few fixes. For more details on the my leaving, have a look at this topic on the forum.
What's New in ReNamer 4.12:
* Fixed a very nasty Access Violation problem, caused by 'Always On Top' option;
* Included recently added options to the statements of Replace and Remove rules;
* Skip extension option made optional for the Translit rule, instead of default;
* Load from User Input dialog supports Unicode text, and UTF-8 encoded files;
* Fixed previously broken functionality to Delete Files to Recycle Bin;
* Workaround for a Windows error message 'Please Insert a Disk' which
  was given on initialization of the Browse dialog for every empty drive;
* Step for Incremental Serialization can be negative, for backwards counting;
* Last used folder for Add Files dialog is remembered, was recently broken;
